Red, 81, mot Oct 17, 37k on clock. 3.5 v8, 5 door 6 seater.
Galvanised chassis, full length galvanised roof rack, galvanised front bumper. 5 practically brand new bfg Goodrich muds, 5 modular wheels could do with another lick of paint. Brand new fuel tank fitting between xmas and new year, serviced in October. Fuel pump looks fairly new as well. Been told an auto spark was paid 700 quid to sort out some wiring. There is an overdrive unit there as well but needs fitted.
Bad bits
Rear diff leaking from prop side (have seal)
Gearbox leaking
Oil leaking from sump gasket I think
Usual land rover leaks round about door seals
Bulkhead has a couple of bits of filler so will need attention soon
Between rear doors and seats needs welding both sides.
Did have lpg system I have started removing.
All the doors could do with being replaced or repaired.
£2750
Located ardrossan, North Ayrshire.
Cash on collection
Land rover series 3 109 stage 1
- Attachments
- FB_IMG_1483801336989.jpg (60.03 KiB) Viewed 10661 times
- FB_IMG_1483801316340.jpg (94.17 KiB) Viewed 10661 times
- FB_IMG_1483801326001.jpg (68.06 KiB) Viewed 10661 times
