left manifold
left manifold
Just fitted RR headers to the girl jee its real tight in there now had to do so due to manifold cracked off at flange and cast iron is hard to work with when welding it back together. Result off swap even less room on left side due to chassie rails 5mm but sounds great with twin system and through mufflers and feels like more power. next thing is the blingy RR wheels with copper tyres them the fuel injection
If you want some photos, look here:
http://stage1v8.org.uk/phpBB2/viewtopic ... c&start=45
You will find some photos towards the bottom of the page.
Stirling
Videos:
& Others!
Videos:
& Others!
I'm pretty sure he means the EFI manifolds. Because range rover extractors don't fit the stage 1. The Chassis rails are much closer together and fouls. I think some people in the past have managed to fit the extractors by heating them and bending them to hug the block more closely.
The EFI manifolds are supposed to be a pretty good compromise though.
Stirling
Videos:
& Others!
Videos:
& Others!
manifold
Yet again sterling is correct in that description of that area
o f the world of exaust & yeah that what i put on !!!! little issue withe hole lineing up little chain saw file and no problems yet 48 hours maybe so far of running time so i spose we se yeah.
