Cleaned the points, reset the gap corrected dwell to 26 degrees and then checked the timing which was at TDC. Reset to 6 degrees BTDC and wow is that better!
Need to check and regap the plugs and then on to the carbs.
Taking a day off on Monday to look at the tub and generally have a day off!
Seb
dwell & timing
dwell & timing
Re: dwell & timing
I did the dwell on mine today, it's really easy with the adjustment outside the distributor!sebking wrote:Cleaned the points, reset the gap corrected dwell to 26 degrees and then checked the timing which was at TDC. Reset to 6 degrees BTDC and wow is that better!
Went to do the timing and there's no timing mark on my crankshaft pulley
Any ideas how I find TDC easily?
- doggreen10
Re: dwell & timing
Take out No 1 spark turn engine over buy hand, with small screew driver in spark hole when piston at top you have TDSchoc-ice wrote:I did the dwell on mine today, it's really easy with the adjustment outside the distributor!sebking wrote:Cleaned the points, reset the gap corrected dwell to 26 degrees and then checked the timing which was at TDC. Reset to 6 degrees BTDC and wow is that better!
Re: dwell & timing
Did that, as Sod's law will tell you, the alternator belt wasn't quite tight enough to turn the engine so I had to sit on the front wing with a spanner on the alternator, my foot pressing on the belt and my right hand holding the stick in the spark plug hole....doggreen10 wrote:Take out No 1 spark turn engine over buy hand, with small screew driver in spark hole when piston at top you have TDS
Job done though, thanks all
