Ok... there are fixings in the C posts for shoulder seat belts. I've got belts and other bits in a box. where do the other bits fix?
Anyone got some pix? that would be top!
Seat belts in the "middle" row of a SW
help
Come on people! I need pictures of the mountings or however you have fitted them.
Hard to say since I have never done it on a station wagon before. Guess it depends on what the contents of your box look like. If you have a look through the Optional Parts catalogues that are linked to (IIRC) from this forum you should see the various belt connections. Depending on which type of belt you should determine how it is mounted.
Assuming you have lap and diagonal I would think there must be a corresponding hole in the door pillar. In the catalogue it shows, more or less, which bolts and washers go where.
it was me
I've managed to get them sorted (ish).
Now need to try and get a new tub reinforcer installed without taking the tub off (Station Wagon).
Reckon I can get the one under the seat in too if I move the little panel that sits on the C post
