Bushes
Posted: Tue Feb 26, 2008 3:21 pm
by robert
Are the bushes same as for normal series 3?
If no what are diffrences?
Robert
Posted: Tue Feb 26, 2008 9:28 pm
by stirlsilver
I'm pretty sure they are the same... Just take some measurements of the ones you have fitted and compare them with any that you are going to buy... But I recommend you get nolaphane bushes. Makes life Soo much easier!
Posted: Wed Feb 27, 2008 12:03 am
by robert
Thanks for response, I wish I can measure it. I'm asking as I'm in UK at the moment and car is in Poland, it makes buying spares bit dificult. Just a bit.
robert
PS What is material of bushes which you mentioned?
Posted: Wed Feb 27, 2008 4:58 am
by stirlsilver
A nolathane bush is a type of Poly bush. It doesn't have the steel sleeve on the outside so it can't seize into the leafs. They come in two halves with a inner steel sleeve.
This site should give you some insight:
http://www.redranger.com.au/why.htm
Posted: Wed Feb 27, 2008 8:31 am
by Andy Dawe
I used an orange polybush set polybush sell differing grades of hardness depending on colour. Orange was recommended by Chris Perfect when I bought his parabolic suspension. Easy to fit and/replace and 2 yrs on are outliving the originals easily.
