Hello,
does anybody know whether the Stage One needs valve shaft seals or not?
Mine doesn`t have any, but I know that they are available.
My engine needs about 1 ltr oil on 1000 km, but when I run down a hill without throttle,and then pull down the accelerator there comes oil-smoke out of the exhaust pipe. It isn`t a problem yet, but I`m a little unsure about the seals. Does anybody know what it is about?
Regards
Horst
Seals from the valve shafts
Exactly the same thing with mine... I've made a number of inquiries about it but never really got a straight answer. I think I fitted the seals with no change... can't quite remember tho.
Stirling
Stirling
Stirling
Videos:
& Others!
Videos:
& Others!
I remember hearing that sometimes people removed them due to insufficient lubrication down the valve guides. I actually fixed the smoking problem by putting the crank case under a slight vacuum which helps reduced the amount of oil that is sucked in on engine breaking.
Stirling
Stirling
Stirling
Videos:
& Others!
Videos:
& Others!
