pictures of engine bay
Posted: Fri Oct 28, 2005 1:21 am
by arcticrover
One more request
Can everyone post pictures of their engine bay? I need some comparisons to see where a few miscellaneous items are supposed to go
Like my heater selector cable, which must have rusted right off of its mount. I also have some plastic tubes which are emanating from the transmission/t-case which are just sitting in the engine bay, not attached to anything. They are bent at a 90 degree near the end.
Posted: Fri Oct 28, 2005 7:02 am
by V8darren
Hi Mate,
Can't help with the pic although the plastic tubes from the transmission are extended breather pipes, stops water getting into the transmission, very bad
Darren
Posted: Fri Oct 28, 2005 3:12 pm
by arcticrover
Thanks. That is as I thought, but someone else had eluded to them being vacuum lines that should be connected to the top of the carbs. I may have read that post incorrectly.
Posted: Fri Oct 28, 2005 6:46 pm
by db
Probably not enough detail for you at
http://www.stage1v8.org.uk/tech/Engine_Bay.html
However, somewhere I've got some photos I took of a vehicle which was for sale at the East Anglian Off Road show in 2004. From memory they show a bit more so I'll stick them in a gallery when I find them.
Posted: Fri Oct 28, 2005 8:13 pm
by V8darren
Hi Mate, only me again.
I forgot that I had posted some pics of the engine bay for another user earlier this month.
Here is the link, hope its of use to you.
http://www.stage1v8.org.uk/phpBB2/viewtopic.php?t=44
Darren
Posted: Sat Oct 29, 2005 5:37 pm
by db
I've now found and uploaded the photos which I mentioned earlier and they can be viewed at
http://www.stage1v8.org.uk/engine_bay/index.html
If you want more detail you can click on the 800x600 picture to see the 2048x1536 original
Posted: Sat Oct 29, 2005 6:03 pm
by arcticrover
BRILLIANT! Many thanks. This will be extremely helpful in my reconstruction efforts.
Posted: Sat Oct 29, 2005 8:30 pm
by Bumpkin
DB
Those piccys of the engine bay. Any more of the rest of the Stage 1. Only one i've seen in the same colour as mine.
thanks
Terry
Posted: Mon Oct 31, 2005 8:56 pm
by db
Bumpkin wrote:Any more of the rest of the Stage 1. Only one i've seen in the same colour as mine.
I'm afraid not.
The only ones I didn't upload were some close-ups of the catch for the bonnet lock which I took since my bonnet had been replaced with one without that. I wanted to see how it was fitted since the previous owner of mine had found the one he'd bought but not got round to fitting and was going to send it to me.
The only other info I can tell you is that I'm pretty sure it's a HCPU like yours (you can see it's a truck cab in a couple of the photos) and it had 16000 miles on the clock and he was asking for 3950 ono
Posted: Tue Nov 01, 2005 6:40 am
by Bumpkin
db
How lond ago?
Posted: Tue Nov 01, 2005 10:50 pm
by db
It was 6 / 6 / 2004
