Gearbox swap
Gearbox swap
I finally got around to starting on my gearbox swap today. There are 4 main variants of the LT95 all of which have differences that prevent them from being a straight swap. the versions are Stage 1, Range Rover, 101 & 110 V8. I picked up an LT95 that came out of a 110 V8 a few weeks ago.
Its basically the same gear box but does have a couple of differences that require taking some parts from the old gearbox.
Spot the difference????
The handbrake mechanism is different
and the handbrake is its self is different.
These to are not a major problem. Just a couple of bolts and they come straight off.
What is slightly more of a pain is that the front and rear output flanges/shafts are different and need swapping.
Rear
and front
So far I have managed to swap all of these bits over and refitted the stage 1 handbrake. Tomorrow I plan to replace things like reverse and diff lock light switches and generally tart it all up a bit prior to refitting.
Rear
and front
Hi John,
I did the gearbox swap a few month ago. I fitted a range gear box, changed intermidiate gears, because the range gear box was overgeared. Then I fitted an overdrive. Runs good now. I had to change all the things you mentioned, and also the speedo drive gear. Changing the gearbox was not difficult, but it was much work.
Wish you good luck.
Horst
Wish you good luck.
Horst
That could be me
I have a unknown age / condition LT95 gearbox in the floor of the garage. I bought it because it was attached to an overdrive. I think it came from a Range Rover. It does not have a bell housing attached.
I have my Stage One tore to bits now - for a seperate project. The Stage One's gearbox has the typical whine or whirr noise that everyone else seems to have.
I am faced with a decision. Do I try to swap the whole gear box or just the overdrive?
The lazy germ is biting me and I am thinking I will just live with the noise and swap over the Over Drive - especially since the other transmission could - theoretically - have the same noise. I would hat to swap everything over and be where I started. Plus - the weather is great and I need to quit working on this thing and start driving it.
What says the community?
- gary_in_nz
Its in!
Couldn't continue working yesterday as I appear to have pulled something in my back hauling the gearbox around on Saturday. Have refitted the box but still have to sort all the cables, clutch etc etc
I haven't transfered the overdrive yet as I want to give the box a run out first to see if its as good as promised.
LT 95 and overdrive
Hi all together, hi firemanshort
Perhaps this may help you: Fitting an overdrive is a rather easy job, but you must pay attetion: After the snap ring and the main gear being removed, the main shaft is able to float towards the front of the car. This MUST NOT happen, under no circumstances, because the thrust washer may fall down, and must be centralised new. This happened to me, and I can tell you, it is very much work. So if you want to fit the overdrive gear, you better should secure the main shaft, so that it isn`t able to flow.
My overdrive howls a little bit, not serious; but by rpm getting lower, I think it helps to save fuel. I´m pleased to have fitted it, beacause I have more gears. For example, if you drive up a long hill, the fourth gear is sometimes to long, but the third is to short. In this case you can use third gear and overdrive engaged.
My old LT 95 was rather noisy. I don`t know how much miles it has done, so I bought a new one which has done about 40000 km from an accident car. I opened the gearbox, and it was totally clean and looking like new inside. After fitting this gearbox, there was also a little noise, but not loud. People who drove the Lt 95 in the past told me, that this gearboxes are allways a little bit noisy- don`t care about it. (Haynes Service and repair manual "Range Rover" says nearly the same).
If I were you, I would drive the noisy gearbox with the overdrive being fitted this summer. Maybe, the next winter will bring time enough to overhaul the gearbox, then you will be secured to have a good one.
I do so myself. I will rebuild my gearbox next winter, because doing a good job needs time.
good luck and regards
Horst
Horst
I'm interested in your overdrives. I have a 4 speed LT95 on my (very early) '83 110, but had been told that it was not suitable to work with an O/D. I presume my box must be pretty similar to those on Stage 1s - so what O/D works and where can I get hold of one ?
Nick
Nick
Hi Raggylad,
the overdrive should fit to your LT 95 too. As far as I know, it fits to all LT95 gearboxes. It has been instaled in the old Range Rovers, in Stage Ones and in early 110 V8. I bought mine in the Netherlands, there is someone who restores overdrives. I paid about 450 Euro, with warranty for a half year.
I`m peasured with mine, in spite of beeing a little noisy. Have a look at Johnny`s side, I think there is a manual about the overdrive. Overdrives for LT 95 are rather rare. You must look intensivly, if you want to find one. I saw one somewhere on google, it was for sale in Switzerland a few month ago.
In Germany I know one for sale, but it costs about 900 Euro, beeing rather new and compete with all details.
regards
Horst
regards
Horst
http://cgi.ebay.co.uk/Landrover-overdri ... dZViewItem
Here's one on ebay.
As far am I'm aware there is only one overdrive that will fit Series V8 Land Rovers and they are all the same apart from levers.
I purchased one from ebay about a year ago and it sat in the basement for 7 months whilst looking for a set of levers to make it work. With luck a set turned up on ebay and I won the items at a premium. My misses was not impressed of the lumps of metal for a decent amount of cash.
Fitment was easy and it was worth every penny. I have returned 20mpg at 50mph forced by following a mate with a car transport trailer. I can leave it permanently engaged whilst pottering around. However it increase the whirring noise this post first mentioned.
Also for sale is what appears to be the overdrive coupling for the V8 Overdrive. I may be wrong but the 4cyl ones have a Brass/Bronze toothed ring this one looks like the one I had to fit into the LT95 Box.
http://cgi.ebay.co.uk/LAND-ROVER-FAIREY ... dZViewItem
Here's one on ebay.
see Ginga for shifting levers
For those seeking the proper shifting levers - see Ginga. He has a pattern from genuine parts to re-create new parts.
-Firemanshort
-Firemanshort
Hi Guys
I do indeed have the pattern for the linkage (Thankyou Firemanshort) I have had it rengineered and it works fine.
It cost a lot for sand casts etc (Laser cut could not get the angles) but I now have a mould blank and the ability to make more as and when required.
Initially I also did as Johny boy did and cut a slot in the middle seat but hated the draught, hence the reengineer route to get the lever by the bukhead.
BTW now on my third gearbox swap so getting quite good at it. And had the same problems as eveyone else.
First has just failed so another swap is on the way However i will end up with a spare with overdrive out of all the mashed pieces. The troble is you cant test a box on the floor very well until its in.
Theres always a way !
