It just wont run right
jonnyboy
Post by jonnyboy »
I finally thought everything was ready for the MOT but the engine decided it didnt want to play.
I just cant get my engine to run well.
Every time I think its running right I go for a run and after half a mile it starts to pop and fart and loses all power. It seems to start backfiring through the carbs.
Heres what I have done:
I have checked the tinming marks corespond to TDC on cylinder 1 and set the timing with a strobe to 6 BTDC.
I have fitted new plugs, leads, rotor arm and cap with some better quality ones than the cheap crap that was on there.
I have balanced the carbs (strombergs) and adjusted the mixtures using the technique described http://www.gerull.nl/mg/technics/carb/carb_tuning.html
I went through it all this morning, backing the mixture adjustments right back and starting from scratch and initially it ran sweetly. It had a smooth idle and reved freely.when for a drive around the yard and it was all fine. Went for a run down the road and had to get towed home.
Any suggestions??????????????
Jon - M1CQO
My Website
martin hughes
Post by martin hughes »
Could it be fuel related?
Is the pump running ok?
Have you checked both fuel fillters?
Are the float chambers filling as required?
1982 109 V8 Station Wagon
1965 88 Short Wheel Base
jonnyboy
Post by jonnyboy »
The fuel filters were a bit clogged up and I think there may be some wear in the spindle shafts causing an air leak.
I have taken the carb's off and brough them home and am going to have a go at stripping them down.
Jon - M1CQO
My Website
martin hughes
Good idea.
You can get the carb kits from craddocks, there are 2 types of kit one has more parts than the other althrough you will need both for a strip down of each carb, you will end up with some duplicated items for spares.
you will also need a steel ruler to set the float height.
Did you check the filtter in the base of the fuel pump?
mikeinbeverley
Post by mikeinbeverley »
I finally binned my leaky Strombergs after unsuccessful re-builds & got a Webber. Together with a 1:283 rear diff I didn't think I was in the same vehicle! Accellerates effortlessly, makes the vehicle seem lighter. The power no longer fizzles out as the revs rise. I'm not kidding. I've had the "Truck" for past 20 yrs & done loads to it, but nothing has made a difference like this. But now I'm stuffed because its making water disappear at rate of 26m to the half-litre!! Just needs a new engine, that's all! That's Landrover life!
jonnyboy
Post by jonnyboy »
Yep, that was full of gunk as well!
I plan to fit either a weber or a pair of SU's but need to get it running first for its MOT. Then I can bring it home as its currently on a mates farm near york and I am in Barnsley!
Might even get really silly and fit a megasqurit EFI system :D I am already planning to get rid of the dizzy when I get it running.
I have stripped down one of the carbs tonight and there is a lot of play in the shaft so it looks like I will either have to rebush it or throw them away and find a cheap alternative.
Jon - M1CQO
My Website
martin hughes
I have seen brand new carbs on the web for £65 each
db
Site Admin
Post by db »
Although you're checking the carbs and have replaced most of the ignition bits
I wouldn't rule out the coil. I had similar problems on my Lightweight with a
coil which failed when it warmed up but was fine for the first mile or so.
jonnyboy
Post by jonnyboy »
I forgot to mention I replaced that as well :D
Got a large box full of nearly new pattern part ignition components in the garage!
Jon - M1CQO
My Website
jonnyboy
Post by jonnyboy »
One suggestion I have had is to just run it on LPG and either just use the carbs as throttle bodies or get rid of them altogether and rig up some kind of dedicated throttlebody.
If I had the time and the money I might consider it as I want to fit LPG in the future.
Jon - M1CQO
My Website
foggydave
Post by foggydave »
Could it be the ballast resistor breaking down under temprature load.
This does give symptoms that appear to be ignition related.
To test just bypass the resistor for a short time to test but not too long.
jonnyboy
Post by jonnyboy »
Not thought of that so will give it a try. It now gives me problems when cold so I am not sure if its temperature related.
I have been offered a pair of SU's from a discovery that I am hoping to pick up this weekend so will give them a try asap.
Jon - M1CQO
My Website
foggydave
Post by foggydave »
What ignition system are you using.
I use Lumenition electronic and had problems with cutting out when hot
I was told that Lumenition wires from the module to the dizzy especially the 3 pin connector hate getting hot so I re-routed them away from the heat and also shrouded them in a bit of washing machine tube and everything now seems ok
Also the module does not like getting hot either.
OR
This guy had fuel pump pressure problems ie pressure too high which gave the same symptoms as you are getting
http://www.v8register.net/subpages/V8NOTE328.htm
Hope this helps
jonnyboy
Post by jonnyboy »
Its currently running standard points ignition. Hadnt thought about the fuel pump, I would have thought that any excess presure would have been bleed off down the return feed to the tank though :?:
Something else to investigate :D
Jon - M1CQO
My Website
