Landrover Stage 1 3.5 V8
Tax 5 months MOT till end Sept
I will send pictures as required any more info ring 01162234164
Location Leicester England
I am looking for £2300 as it is.
All the bits I took off to uprate the motor are included so if you want to de-rate it and refit the Stromberg/Zeniths there should be no problem
The Weber/manifold/camshaft/lifters etc are worth in the region of £700-£800 if you wanted to sell on Ebay or similar
I am open to offers and will be totally honest in all descriptions as I do not want to waste anyones time.
Engine 3.5 V8 low compression
New 4 barrel Weber carb
New Pancake filter
New inlet manifold
Tubular downpipes
Self fabricated exhaust system
Exhaust box,s stainless steel
Lumenition Electronic ignition
Manual switch Pacet type fan
Fairy overdrive (Noisy but works ok)
Difflock vacuum switch replaced by manual lever
Not fitted spares
Real Steel high lift cam shaft
Set Rhoades lifters
Spare pancake filter complete
Original Fan
Water pump
Not working
Heater valve to matrix broken
Body
Condition of body
Front wing crease along top
Rear side panel dented at top
Both door tops very bad
Both doors have rust and holes in frames
Replacing both doors was my next job.
Condition of chassis
Rear chassis has been welded in the past but no rot on beams and
outriggers
Condition of bulkhead
Generally very good with no rot
New complete footwells
Top dash has been stripped of plastic
Bottom dash (heater box/diffuser) has been removed to facilitate
Foot well fitting and needs replacing (putting back).
Hole on top/front of bulkhead by door pillar
Axles
New swivel seals and all new oil seals in hubs
General
Fitted Bull bar with 2 spot lights
Fitted Rear wheel carrier (opens with door)
Spares
2 inlet manifolds
1 set Stromberg Zenith carbs nearly new
1 set Stromberg Zenith carbs old
1 set SU carbs old
Air filter housing
Standard Exhaust system (used)
Sundry bits and bobs
Light bar with work lights and amber beacon fits on rear
Very good spare back door (blue)
Side windows to fit hard top sides
Ladder roof rack
Pair of side steps
Overall
Motor is in very good condition and has been well maintained runs and
Behaves very well
The consumption is on a par or better than a 2.5 engine returning figures
of 14 – 16 mpg this coupled with the performance of a V8 makes it a far
better motor than the standard series
The Weber carb setup also gives a big smile factor when using a lot of
throttle and makes driving this Landrover a real treat
