fuel & water temp voltage regulator
martin hughes
Post by martin hughes »
Does anybody know where the voltage regulator is which feeds both of the gauges through light green wires?
Has anybody experianced problems with this?
1982 109 V8 Station Wagon
1965 88 Short Wheel Base
Andy Dawe
Post by Andy Dawe »
Normally found on the rear of the clocks (speedo/water temp Gauge)..
glencoyne
Post by glencoyne »
Spectacularly unreliable. How can something so simple give so much trouble? All there is in it is a bimetallic strip and a couple of contacts. Tends to stick, resulting in high temperature and fuel level readings. If anyone fancies making a solid state replacement, I'll buy a few.
Richard
