Discussion about the Register (and V8 powered vehicles other than the Stage 1)
Moderator: glencoyne
Tom G
Post
by Tom G »
How did you adjust the timing? is it somthing simple like twisting the dizzy?
1988 V8 110 CSW.
martin hughes
Post
by martin hughes »
had my stage 1 converted for £1150 all in, this was using a 120 litre tank set across the rear wheel arches.
1982 109 V8 Station Wagon
1965 88 Short Wheel Base
Tom G
Post
by Tom G »
Across the wheel arches? How does it fit?
If my chassis is at all similar then it would go above the chassis and over the rear prop shaft?
1988 V8 110 CSW.
