Meaning of "C" Suffix?
arcticrover
Post by arcticrover »
Rimmer Bros codes my engine as belonging to a 1983-1985 Saudi 5spd Range Rover. However, my engine is 20D00008C, and their site only shows A or B suffix for the 20D series. Does anyone know the meaning of the "C" suffix???
Ginga
Post by Ginga »
Have you tried http://www.v-8.org.uk They have an engine No section
Regards
Ginga
Theres always a way !
arcticrover
Thanks, but they are no help on the suffix . . .
Stageone
Post by Stageone »
Original engine number for the Stage One is between 10G00001 and 12G00001, so yours is probably non-original.
Looking in the Range Rover Repair Operation Manual 1970-1985, it lists the "C" suffix as "Emission Controlled", and compression ratio of 8.25:1
and there is some info on carb needle type and ignition procedure.
HTH
Marijn
Marijn
arcticrover
Strange. My block is also stamped with 8.13:1 for CR. The mystery remains. . .
Stageone
Post by Stageone »
My mistake.. looked further in RR repair manual, it says:
Saudi Arabiaand Gulf States 8.13:1 Copression ratio (em.controlled)
Engine prefix ID 20D & 21D
Distributor serial no. 42056 Electronic
Idle speed 650 to 750 rev/min
Ign. timing static 6 degr. BTDC
it goes on about crank angles for decelrating check
Marijn
arcticrover
Thanks!
