UJs for rear prop shaft
Does anyone know where I can find the correct part number for replacement UJs (spider/hardy spicer joints) for the rear prop?
Original LT95 gearbox to Salisbury axle final drive unit.
Cliff.
Re: UJs for rear prop shaft
You want a Hardy Spicer number? Generally it's just a trip to the local bearing shop. If not by catalogue they will measure as they are a standard joint. The key point is to ask for 'with grease nipple'.
Otherwise RTC3346, same as the front and on numerous different LR models.
Nope, I just wanted a number for the rear 109V8 propshaft UJs. I only mentioned the words 'spider' and 'hardy spicer' for those pedantic souls that might tell me not to call them Universal Joints (UJs).
Thanks very much for your reply, I was unsure if the part number you quote was applicable to the 109V8 prop since the S3 parts book only gives whole propshaft part number and doesn't list the UJs separately. I'll likely use a pair of the GKN greaseable versions. I used their joints for my D2 front prop rebuild and have had no problems.
Moved to my restoration thread.
