What are folks doing for brake servos?
Suffice to say AEU1043 is not leaping out of the internet at me.
Will a Type 50 STC2878 (early 90/110) with the pedal end modified do the trick?
Replacement brake servo
Re: Replacement brake servo
This should be usable instead
https://www.brit-car.co.uk/search.php?q ... PerPage=10
109" 1982 SIII CSW Stage 1 V8
109" 1965 SIIA FC
1991 RRC Vogue SE
109" 1965 SIIA FC
1991 RRC Vogue SE
Thanks. STC1816 is the one.
"AEU1043 (STC1816) - SUPERCEDED BY STC1816"
Seen the price of the Genuine one
I needed one last year. My garage supplied and fitted a pattern one and said they'd guarantee it for a year if they did so, No problems so far (I hope not famous last words) It came in a Britpart box and was made in Taiwan, so I at least feel I'm doing my bit to support non-Communist Taiwan!
109" 1965 SIIA FC
1991 RRC Vogue SE
109" 1965 SIIA FC
1991 RRC Vogue SE
I've just looked a bit further at this & the STC1816 is the standard Series 2/3 6" servo. where the V8 (or mine is) has an 8" diameter servo.
The type 50 is also 8" & discussed here: http://www.expeditionlandrover.info/dual_brake_conv.htm
I'm not to keen on making the brakes worse.
Yes, you'd just need to alter the clevis by re using your original. They both have the same rebuild kit too (18g8951l), so you could just rebuild your original instead.
