LHD Steering Arm RH FRC1940
tomo_
Post by tomo_ »
Looking for one.
Is conversion from standard late 4cyl 109 possible ?
Def 110 200Tdi, work in progress on Stage 1
Re: LHD Steering Arm RH FRC1940
Short answer, no.
Slightly longer answer, what is your definition of "arm"?
tomo_
Post by tomo_ »
to replace arm FRC1940 with relevant S3 4 cyl arm.
seems quite similar but is not.
What I found is that someone already managed to accomplish this with set of shims:
https://www.designdevelopmenteng.co.uk/ ... p216718930
Guessing then that you want 530991.
tomo_
Post by tomo_ »
I do need 530990 now found out that with the kit I can use it in place of FRC1940
T.
