Gear lever
Gear lever
Can anyone identify this gear lever:
ImageUntitled by Geoff172, on Flickr
It looks as though it's for a Stage One, except that it bends downwards above the damper instead of the other way! If it's not for some other model, could it have been manufactured incorrectly? (possibly in some confusion over LHD and RHD versions, though it appears neither to me??)
Re: Gear lever
Range-Rover.
Re: Gear lever
I thought they were all straight.
Re: Gear lever
Look at any picture of a four speed RR driving position. The stick almost lays back over the tunnel. Otherwise you need to start providing dimensions as the are multiple LT95 gearsticks that all look similar and all end up with the knob in a different place. You can use a 1110 stick in Series III but the knob ends up left and forward..
Re: Gear lever
Thanks. I'm trying to identify the particular model and a part number.
