Low vacuum on carb
Posted: Sat Oct 13, 2018 6:14 pm
by Matt1
Hi. I can’t get my rover 3.5 v8 to idle.Theres loads of vacuum on the near side carb but very little on the offside carb.It has zenith carbs fitted.could it be an air leak that causing low vacuum and are there any common places that it would leak from?i tried a search but couldn’t find an answer. Thanks Matt
Re: Low vacuum on carb
Posted: Sat Oct 13, 2018 10:34 pm
Is the piston sticking?
Or (although rare) has the diaphragm split?
Posted: Sun Oct 14, 2018 5:40 pm
by Matt1
Thanks. They’re ok. Going to get it smoke tested.
Posted: Fri Oct 19, 2018 11:49 am
by udo1-ton
If there are later carbs fitted, there should be an additional spring loaded valve fitted in the throttle valve. When the spring got weak over the years there is an bypass at idle revs. The best solution is an exchange to the standard unit without valve or the valve can be soldered.
Posted: Mon Oct 22, 2018 7:31 am
by Matt1
Ok. Thanks for your help
