High Torque Starter motors - Experience???
Posted: Fri Dec 23, 2016 8:40 am
I am fitting tubular manifolds (SD1) to the truck and they clash with the solenoid on the side of the starter motor.
I have two options - Fit a standard SD1 starter motor with the under slung solenoid or fit a Rover SD1 V8 Uprated Hi Torque Starter Motor.
my question is: does anybody have any experience of using the Hi-Torque starter motors, are they a vast improvement over the original design and have they had any problems with them?
size wise - notably smaller?
thank you
thank you
