Prop shafts
Posted: Wed Oct 26, 2016 8:53 pm
by MadMatt
Hi, i own a stage 1 V8 over in Australia, had some trouble with the front prop shaft assembly, specifically the double cardan joint centeral bearing , does anyone know of a rebuild kit or suitable replacement parts?
cheers
Matt
Re: Prop shafts
Posted: Wed Oct 26, 2016 11:39 pm
Your Saginaw shaft uses all standard driveline components. Any driveline shop and any better auto parts shop should be able to supply the universal joints or the spring thing in the middle of the double joint. Repairing the slip joint means cutting it off, re-welding on a new one and balancing.
Re: Prop shafts
Posted: Sat Apr 08, 2017 6:59 am
by Lardy
The front prop uj on the stage one according to the previous owner has given up life on a couple of occasions whilst under his ownership.
It in turn has attacked the underside of the vehicle and smashed a lump out of the bellhousing is this a common fault?
I seem to remember reading something about this on AULRO but cant find reference.
Any info appreciated.
Re: Prop shafts
Posted: Sat Apr 08, 2017 7:17 am
If it lets go then it will take out the output housing and put a few dents elsewhere.
However the unit itself is very reliable. If found to fail then it will be on a car that hasn't been maintained. Just as likely that he didn't replace the Nylocs or tighten them adequately. Keep pumping grease in at the required intervals and the only remaining issue is the slip joint. Which do wear and add to backlash.
Re: Prop shafts
Posted: Sun Apr 09, 2017 8:33 am
You are likely to feel the UJ's through the floor before they break.
Re: Prop shafts
Posted: Tue Apr 11, 2017 10:07 am
by Lewy
My 110 snapped a front uni and put a hole in the side of my gearbox years ago.
