SU HS6 jets etc
Posted: Wed Dec 30, 2015 9:05 am
Hi all,
Well I keep on accumalating parts I've just bought a pair of SU HS6 1.75" carbs to replace the HIF44s that are currently fitted. The HIFs are working fine, but I prefer the HS6's simplicity and ease of setting up. I was wondering if anyone else is running HS6s, and if so what needle, jet and spring you are using? The HS6s came off a V8 so they'll be usable as is most likely, but I'd rather get them spot on as part of their refurbishment. I'll contact Burlen if nobody here has first hand experience (and I'll report back of course!)
TIA
TIA
