SU carburettors
SU carburettors
In order to finish off a refurbishment that has already taken some 5 years I need to source 2 good replacement SU carburettors and linkage together with a manifold.My garage seem unable to source them after making extensive enquires. I don't want to spend £1500 on an upgrade kit which is the only alernative I have been. Given.Any ideas? Thanks.
Re: SU carburettors
1500 squid seems like a lot of money.....
Can you source the Edelbrock parts? The intake manifold and 1440 Carb are only a few hundred $$ (USD) combined and if you take the time to install yourself - you save even more cash.
Re: SU carburettors
That is very helpful - thanks.It looks like you can get Edelbrock in the Uk so I will check them out.Cheers.
Re: SU carburettors
Just to confirm, you are after a pair of SU carbs, with linkage and manifold?
I will ask how much this will cost as I do happen to know where there are some
Re: SU carburettors
Hi, I have a couple of sets of SU's with all linkages and manifold.
Along with many more Stage 1 parts----chassis,axles etc...
Re: SU carburettors
You can get the SU's from Burlen
