Available bits?
Posted: Mon Nov 17, 2014 10:13 am
HI looking to get a stage one and there were some bits missing from one I looked at - not sure if available or not?
The radiator appears to be held on an "A frame" visble through the grill - it was missing
also the air ducts from the strombergs and air boxe was all missing - is it the same as range rover?
is radiator available and same as other models - range rover?
Also are front drum brakes different - wider? do the series 3 109 front brake slave cylinders fit, i.e., same repair kit from suppliers?
thanks
Darren
thanks
Darren
