Help,
Can anyone tell me if I can change a manual gearbox for an automatic and if so what versions will do the trick?
Thank You for your consideration.
GEAR BOX CHANGE
Re: GEAR BOX CHANGE
Short answer. Yes.
Long answer won't fit here. Nothing will will merely bolt in. All other options will require a lot of work.
