LT95 PTO Wanted
v8alligator
LT95 PTO Wanted
Post by v8alligator »
Hi All,
I am looking to put either a hydraulic or mechanical PTO on my stage one.
Has anyone got either a complete forward facing PTO setup with drive shafts or a complete hydraulic PTO pump setup to fit the LT95 which I could purchase?
Happy to travel to collect or arrange for a carrier to collect if outside of the UK.
Regards
Bryan
Re: LT95 PTO Wanted
Good luck with that.
Australia is likely to be the best bet (they were used a fair bit on the military Stage ones and 6x6 Perenties). Try on AULRO. Thomas is a good brand.
If you can't find one, then you can use a LT95 off a Range Rover. You will have to redrill because the Rangie PTO casing sits horizontal and not diagonal, as it does on the Stage 1. Some are also a bit longer. Aside from that, they are pretty much the same.
