How can I remove the restrictors?
nievesytinieblas
Post by nievesytinieblas »
How can I remove the restrictors without breaking? I have removed the air intake manifold but I do not know how to access the internal clip that holds the restrictors (ERC3729).
Restrictors ilustration
Thanks in advance.
nievesytinieblas
Re: How can I remove the restrictors?
This is a picture of my manifold without a carburetor.
nievesytinieblas
Solved: How can I remove the restrictors?
Finally the restrictors are out. I followed disco2hse advices, I created threaded holes and I inserted 10 mm screws. Then I slowly extracted restrictors with a impact extractor pulling the screws.
The inlet manifold has not been damaged.
Restrictors are out.
wpearse
Post by wpearse »
I pulled my restrictors out last week.
One restrictor came out using a slide hammer (bearing puller).
The other restrictor needed the inlet manifold removed, then the clip released from the inside of the inlet manifold.
