Fuel pipe routing
Posted: Sun Jul 22, 2012 10:47 pm
After a little help,
Could someone do me some pictures showing the routing of the fuel lines, towards the tank
(i.e from the pump backwards)
My stage 1 was missing them all, and the manual is a bit vague in this area
Re: Fuel pipe routing
Posted: Mon Jul 23, 2012 2:36 am
No pictures, sorry. Mine run along the top of the off-side chassis rail until they exit the seat bulkhead, then they run along the inside of the chassis rail. But I have two tanks, two facet pumps, two return pipes, and a solenoid to switch between them.
Posted: Mon Jul 23, 2012 8:59 pm
I think my civi ones should move and go along the side at some point ... just cant work out where and due to chassis repairs have lost the position of all the clips
Will need to be someone with a single rear fill tank then
Posted: Sat Jul 28, 2012 7:40 pm
no one able to spare a few mins with a camera?
Posted: Sat Jul 28, 2012 10:48 pm
by harry potter
Posted: Sat Jul 28, 2012 11:28 pm
Looks pretty much the same as mine for the rear tank except mine are clipped. The clips are positioned more less at the points as the cable ties IIRC. Note that I have a whole lot more wire running down to the back too. I am not certain the anchor points are critical, provided they are firm anchors and keep the lines away from hot (including wires) and moving things.
It gets more complicated between the pump and the engine. I think this is where you need to be more careful/specific about where to clip, etc.
Posted: Sun Jul 29, 2012 11:33 am
by harry potter
disco2hse wrote: Note that I have a whole lot more wire running down to the back too..
the wires run inside the chassie rails on mine.
not sure if thats aftermarket or not
regards
Posted: Sun Jul 29, 2012 4:05 pm
Thanks, very helpfull
Civi wiring runs inside the chassis , but Disco 2's is military so aditional wires are probably outside
Posted: Fri Sep 07, 2012 8:36 pm
I am digging the cork screw paint on the drive shaft.
