Qaulity is functional and for the price im noyt botheredI certainly hope they fit around that engine . . . they don't look like they hug as well as I thought they might. They also don't look to be too high quality either
Currently fitting mine. fighting with Right Hand Side at the mo. They do not fit easily at all.
The RHS (if you are sat in the drivers seat) is
1. Clashing with the spring hanger nut and bolt. Solution reverse the spring hanger so only bolt head is showng.
Its still very tight - Depending on the LHS installation I mate have to shuffle the engine and gearbox over.
Having said that at $135 I may break out the angle grinder and start welding.
2. the heat sheilds on the chassis and around engine mounts need to be removed and adjusted acordingly
3. The pipes run very close to the starter motor so a heat sheild is needed.
4. Of greater concern is a potential clash with the stearing box linkage arm. (the one that drops down from the fat searing box spline) Currently my landy is up on ramps so I can test this until its installed.
A probable solution would be.
4a. Rotate the arm back on the splines slightly. Although this may result in a clash with the footbox on full lock
4b. Reverse the arm (The spline may be tapered) as it currenly bend slightly toward engine I might have to use a rose joint as well
4c. Assuming tapered spline cut new splines in arm to suit.
4d. Heat up arm and bend it toward rhs wing away from exhaust
With the left hand side i shall just loosen the whole wing and tip it back just to get the header pipe in easily. The LHS seems to be a better fit, but ive yet to bolt them to the engine.
I have also bought reducers to go from the header pipe connection (supplied) to my current system.
Regards
Ginga
