Header Tank
Posted: Sun May 20, 2012 8:11 pm
by sebking
My header tank is leaking where the the pipe from the rad meets, it's off to be soldered up but as is NLA and just in case any one got an idea of a replacement alternative?
Seb
Posted: Sun May 20, 2012 8:49 pm
by Alicerover
I have a friend who is a fabricator and is pretty handy at welding ally. He makes all sorts of tanks.
Here are some pics of some of his work
He may be able to copy the original tank. I can ask the question if you would like.
Posted: Sun May 20, 2012 9:04 pm
What about using the Defender tank? I know it is different, but is it worth making changes to make it fit?
Posted: Sun May 20, 2012 10:01 pm
Why not just take yours to the local radiator shop and have it fixed?
Posted: Sun May 20, 2012 11:11 pm
uhh,
I think I misunderstood the OP post. By "header tank" do you mean the expansion tank or top tank on the radiator?
Header/Expansion Tank
Posted: Mon May 21, 2012 7:23 am
by sebking
disco2hse - yep the header/expansion tank for the radiator
map1275 - the OP said it was going off to be fixed but was looking for an alternative just in case...
alicerover - nice but looks heavy on the pocket!
Posted: Mon May 21, 2012 8:41 am
by Mrs Bingham
I’m working from memory here so don’t shoot me, but I think the expansion bottle is the same as what was fitted to MGB’s and/or Midgets. As for an upgrade I remember seeing something almost identical on a modern MG RV8 but in plastic :idea:
As for a repair; it should be easily soldered as the pipe isn’t flanged – it goes though the side of the bottle to almost the bottom so that the siphoning effect can return the water to the rad when cooling.
Good luck…
Posted: Mon May 21, 2012 8:44 am
No it's not.
The Land-Rover item appears to be unique. Countless BL products from the 1960s on use similar but not interchangeable expansion tanks.
