Clutch master cylinder - same as standard Series 3?
nick
Post by nick »
Hi folks, hoping this is going to be an easy one - I need to replace the clutch master cylinder on my Stage 1 - (1980, RHD) and I haven't been able to find a separate listing for a Stage 1-specific master cylinder - I have found ones that say "All Series 3 + Defender"?! - surely such a wide range of models wouldn't have the same master cylinder would they? Which is a long-winded way of asking: will a normal Series 3 cylinder fit/work?
Thanks, Nick :)
Do what you like and you'll always like what you do.
Read your parts book or the specifications page in your workshop manual. They are all the same.
nick
Post by nick »
Job done! Thanks very much. Thought that might be the case, just didn't want to shell out for a replacement and then find it didn't fit! Another step closer to being back on the road!
Cheers,
Nick :D
