Heater pipes
Greenmobile
Heater pipes
Post by Greenmobile »
I'm looking to install a Kenlowe coolant heater next to the heater matrix, as proper winter has arrived, but need to install so the coolant flow is the correct way.
Which is the inlet pipe and which is the outlet pipe from the heater?
Cheers,
James
Inlet comes off the back of the block between the heads and has the tap on it.
Greenmobile
Thanks for that. That's tomorrows job sorted then! :D
