I am trying to get hold of a clutch sleeve for a Stage 1 V8 fairey overdrive. The Fairey Part No is 5114-A2. It is designed to come off the LT 95 gearbox main shaft.
Was it you that left a message for me about this last week? If so, I tried ringing you back a couple of times but your mobile was switched off. I might be able to help with the clutch sleeve (I think I have a spare one, will have to check) but not the linkage. You'll probably have to make that yourself.
Andy you need to send wifey away for a few day's, do the conversion she will never know, failing that ply her with drink and copious amount's of nookie until she agree's to your demands he he
I have one fitted. Does whine a bit, but is worth it anytime especially on a trip.Mine may have a lower ratio box than the CSWs as i need the OD to cruise at 75. It works out to about 18 to the gall then.
I have an overdrive on my 88 and wil hopefully fit one to my stage 1 when I get it on the road. The one on my 88 used to whine a lot but its a lot quieter now due to a) better sound proofing and b) using fancy gear oil from difflock.com has seemed to have an effect on it.
Jon - M1CQO
109" Stage 1 V8 Station Wagon - Now gone! My Website
jonnyboy wrote:I have an overdrive on my 88 and wil hopefully fit one to my stage 1 when I get it on the road.
If its off of a series 3 it will not fit (unless it currently uses a LT95 box). Even if the gearbox housing bolt points are the same, the mainshafts spline on a Stage 1 gear box has 8 splines and needs a clutch sleeve Fairey Part No 5114-A2. I suspect your 88 usese an RTC7170 clutch sleeve which is a 10 spline mainshaft interface.
The eternal dimensions (The bit that mates with the overdrive) are however identical
I am currently enquiring with gear manufactures to have a cluth sleeve made using an RTC7170 (which ive bought new) as the external pattern and a LT95 Trunion gear (the gear you take off to fit an overdrive) as the internal pattern. The only trouble I can forsee is if the orientation of the internal and external gear refernces (imagine a sort of TDC sort of thing)are important. (they dont appear to be though as the overdrive engages and disegages at differant rotations).
If anyone has a clutch sleeve i need one. 8 spline Fairey Part No 5114-A2. A broken one would be useful as well to study as a pattern for the gear company
