EGR
EGR
I have problema with my EGR. Anyone has the scheme and Photos of EGR and conections. Best Regards Arturo
Land Rover Serie III Stage 1 V8 1982
Land Rover Serie III One Ton
Triumph spitfire MK4 1974
Citroen 2 cv 1990
Mercedes Benz 404 1969
Citroen DS 21 1971
Citroen 11 BL 1938
Opel Rekord 1900 - 1970 And much more....
Citroen 2 cv 1990
Citroen DS 21 1971
Citroen 11 BL 1938
The tube that is from EGR to a place that i don t know have burned. I have a problem in idle and on higher speed. I change the sparks bobine and condenser and Contact points. Everything was perfect, runs well. Then when EGR tube burned they stay acelareted in high rpm and fail in high speed. I think the problem is from EGR . Any tips? Sorry for my english. Best regards Arturo.
Citroen 2 cv 1990
Citroen DS 21 1971
Citroen 11 BL 1938
Citroen 2 cv 1990
Citroen DS 21 1971
Citroen 11 BL 1938
If you need EGR and air injection to meet Portuguese road laws then you don't have much of a choice. Otherwise the EGR and air injection can be removed.
The EGR valve connects to the middle of the inlet manifold through the big steel tube. The rubber hose that controls the valve goes to the inlet manifold. It is possible that the valve has stuck open but I would suspect that you have either knocked off an ignition lead or created and air leak at the inlet manifold.
Some of the parts are covered in the parts list. Some in the workshop manual and most in the emission control supplement that would accompany your owner's handbook.
removal
On mine I have the EGR Valve and the pipe to the Manifold, everything else is long gone. Have not had trouble getting through UK emissions like this.
What do I need to do to remove the remainder, doesn't seem to do anything. the exploded diagram looks quite complex so can't believe it is still actually working.
Seb
Seb
Thanks, i'changed ignitions leads 2 months ago and it runs good. When i take
off the tube that comes from carburetter and go to rock cover the idle goes down as when i turn off engine and then switch on the idle is good. That is the reason that i think the problem is from the EGR valve. I'm going to make a movie to best see the problem. Arturo
Citroen 2 cv 1990
Citroen DS 21 1971
Citroen 11 BL 1938
Citroen 2 cv 1990
Citroen DS 21 1971
Citroen 11 BL 1938
egr
that sound much more like the vacuum advance than anything to do with the EGR stuff.
So your problem only occurs when you play with things? As opposed to an actual problem?
The engine runs CCV (carburettor crankcase ventilation) so pulling off a vent hose will upset idle.
You still haven't touched the EGR which should only work above hot idle.
as above, removing the vent pipe will cause running problems.
I suggest you check the pipe from the egr valve to the intake manifold. if you have got a hole on this extra air will get into the manifold, upsetting running.
seb - the egr valve is screwed tp the manifold so could be removed ...and a banking plug fitted. good luck getting it off though (I swapped manifolds as it wouldn't come off)
the pipe will need banking at the manifold end. alternatively I can't see an issue with removing the vacuum pipe from the egr valve (won't open then) and leaving it all in place.
When i stoped for instance in a red light, it stay more or less in 1500 2000 rpm sometimes do it sometimes not. It´s not regular. Can you send me photos of your EGR plugged . Arturo
Citroen 2 cv 1990
Citroen DS 21 1971
Citroen 11 BL 1938
Citroen 2 cv 1990
Citroen DS 21 1971
Citroen 11 BL 1938
So it could be worn carburettors or a faulty brake servo. When you have your foot on the brake at idle, the revs go up.
If the valve is sticking, then hook up a vacuum pump and test it. Otherwise it is fair to say that it is old enough to require replacing anyway.
Either end of your EGR plumbing is an imperial thread. All you have to do is unscrew your pipe work, clean the threads and fill the holes with plugs. However, you need to confirm that Portuguese road law permits this. Most first world countries would instantly fail you for the equipment being missing, let alone not working.
As previously explained, I also prefer to fit another manifold. It can be far better to buy brand new. They are affordable and you get five new studs that can actually be removed.
1st world
lol! "most first world" - well in the UK as long as it passes the relevant test - no worries and for the last 10 or so tests mine has passed with the stuff disabled.
tbh, UK and first world in the same sentence opens up a whole load of questions...
Thanks people. MAP it´s not when i have my foot on the brake at idle, the revs go up. Simple when i stopped they don´t get down,stay at 1500 to 2000 sometimes. Tomorrow i´m going to try to make a movie. Does anybody have a photo of egr.
Portugal first world
Arturo
Arturo
Citroen 2 cv 1990
Citroen DS 21 1971
Citroen 11 BL 1938
Citroen 2 cv 1990
Citroen DS 21 1971
Citroen 11 BL 1938
Today i spent 2 hours to remove EGR, with lots of "bala". I close the entris of the tube and i have a big improvement on the idle problem, but it isn't in the right time.
Citroen 2 cv 1990
Citroen DS 21 1971
Citroen 11 BL 1938
Citroen 2 cv 1990
Citroen DS 21 1971
Citroen 11 BL 1938
