Gaskets now on correctly.
Also to note! the pin on the water pump that faces with the pulley was slightly over size so when I tightened up the fan it pushed back through and jammed the pulley! - Watch out for this on third party pumps...
Need a new lead for no8 as in my excitement managed to get it caught up in the fan belt
Once that is sorted I'll get it all timed up, check that it moves up and down the drive way (make a film) and then swap in the nice new carbs.
Engine Swap
manifold fixed
manifold
well having broken the manifold, removed the EGR, fixed some pipe work and nearly there with the replacement manifold here's some pictures!
http://www.landroverv8.com/v8/
older
That's Oliver aged 10 - very useful
"Take that manifold off while I put the kettle on"
moves!
moved out of the garage and around on the drive!
treated it to a wash, sorted the seat runners, put new seat belts in. Now for a horn and to book an MOT!
Seat belts
Hi Seb,
Did you install inertia seat belts, if so what fixings did you use?
Cheers,
Kev
Cheers,
Kev
belts
standard kit from Sams Trim - Securon I think.
