Tie down points
Tie down points
Finally got around to fitting some tie down points into the bottom of the load area. Should stop things from leaping around off-road. Hopefully keep those small items that might fly off in place, in transit, too.
Bolted through the cross frame with high tensile 6mm "gold" zinc bolts. Just in case, I dipped them in fishoilene too. They are marine grade stainless steel and the rings are the same, 5mm rod.
good thought ... shame its taken Lr so long to see the value of them :wink:
