HELP
HELP
I have now tried renewing the carb gaskets, checked all fuel lines, cleaned out carbs, checked ht leads and i am still having the following problems the engine starts and ticks over ok but as soon as i try to pull away or rev the engine it pops and coughs and cuts out, but will always start again and tick over until i rev it and it will do the same, please help i just want to drive it
1982 109 V8 Pickup, a newby with a new project
I had some thing similar it turned out to be the two pipes off the top of the carbs (Fuel overflow pipes) that go to the wing. They were blocked took off the pipes at the carb it was fine thats how I found it.
Worth a try.
or how about air filters blocked, condensor breaking down or coil breaking down. Also worth giving it a compression test you may have a burntout valve (I did).
Darren
Worth a try.
Darren
