LT95 selecting first or second gear is difficult.
All, I have a problem with my gearbox.
Whit no engine running it does not shift to first gear. Sometimes it does but sometimes it does not. I can use second gear but shifting back from 3 to 2 is also almost impossible. Only works with very low speeds.
Any toughts. It this easily fixed. Excusse me but I am not an expert mechanic. Do have common sense.
OK.
Is the clutch fluid level correct?
Are there external leaks at the clutch master cylinder? (where pedal joins cylinder)
Are there external leaks at the clutch slave cylinder? (where slave joins push rod)
Does the gearbox have the correct type and quantity of oil in it?
I suggest you refer to your owners handbook, parts list and shop manual to assist with the above.
I have tried dubbel clutching. does not improve.
Did change the gearoil today. This is a slight improvement.
Next step is de airing the hydrolix and check the pedal settings.
Still feels like something is amiss with the forks or something.
For example.
When I can shift it to gear 1. It wont go in 2.
If it does not go in 1 it will go it 2.
from3 to 2 does not work or very hard. No crunching of gear but it requires a lot of force.
For example.
OK. With that description other things become more obvious.
The easy check is to make certain the clutch is working correctly, however from your description is sounds more likely to be the synchro parts themselves that are sticking or worn or the selector forks are worn. Either way I think you will have to drop the gearbox out if the work on the clutch fails to improve the situation.
