Serial numbers
cogin
Serial numbers
Post by cogin »
Can anyone tell me where to look for the engine and gearbox serial numbers?
If your not living life on the edge, your taking up to much space!
engine number should be on the cyl head to block joint face, on the LH bank near to the dipstick
transmission nuber is on the rear face of the transfer case, just above the bottom cover plate by the handbrake drum
8)
the manual provides illustrations of the locations if you need them (somewhere in the first few pages)
cogin
Post by cogin »
It is possible to read the number off the gearbox with it in and all the bodywork in place?
Read your owner's handbook. The gearbox number is just below the fill/check point.
cogin
Post by cogin »
Unfortunately that is something lost to the passage of time, just needed a rough idea of where i should be looking.
see page 2 here
http://www.landroverv8.com/manuals/seri ... lement.pdf
though the handbook doesnt give any more of a description than my post ^^
