Herky Jerky Beach Driving
First time poster here...i have a 1982 NZ MOD Stage 1 (FFR). Bought in 2007 off eBay from a seller in NZ. Car seems very strong mechanically.
However...sometimes when i drive in soft sand on the beach and traction is limited, I get a very violent "herky jerky" reaction from the vehicle. It made me think if i kept it up something would break. I tried it with the vacuum diff on and off with no change.
It doesn't seem to happen when i have decent traction, even in sand.
Any idea what could be causing this?
Thanks so much!
Thanks so much!
1982 New Zealand MOD Stage 1 24v FFR
I have had the same thing. Check that the wheel bearings are sound, UJs are not worn, and that the centre diff lock is actually engaging. Also, this can occur when you are in the wrong gear, that is the engine revs are too low. I assume also that you were in low range and 2nd or 3rd.
no, its due to the design of the springs, and there resistance to twisting that way, shocks may help reduce the amplitude of the movement but it will still happendisco2hse wrote:Could that be caused by worn bushes on the shocks, or the shocks that need replacing?
essentially if it happens the solution is to alter your driving to avoid it
Thanks. I know what it is. The question was if it is exacerbated on the Stage 1 when the shock bushes or the shocks themselves are worn. The ex-army uses standard front springs IIRC.
For igsmith's sake here is a linky that explains what it is http://www.4x4wire.com/jeep/tech/susp/axlewrap/
To change your driving style, essentially take your foot of the go pedal a bit.
sorry,disco2hse wrote:Thanks. I know what it is. The question was if it is exacerbated on the Stage 1 when the shock bushes or the shocks themselves are worn. The ex-army uses standard front springs IIRC.
tired springs would probably encourage it
I have that problem too, and my transfer box get damage. I have problems with traction and my diff doesn´t work. See the transfer box oil too.
Land Rover Serie III Stage 1 V8 1982
Land Rover Serie III One Ton
Triumph spitfire MK4 1974
Citroen 2 cv 1990
Mercedes Benz 404 1969
Citroen DS 21 1971
Citroen 11 BL 1938
Opel Rekord 1900 - 1970 And much more....
Citroen 2 cv 1990
Citroen DS 21 1971
Citroen 11 BL 1938
More Info
So my LR has original springs (although they don't feel soft) and new shocks.
And it seemed to happen at hi or low speeds.
Anyhow, i reduced the tire pressure to about 25psi, put it in low gear with the Diff Lock on, and was fine in 2nd or 3rd gear. No issues at all.
Thanks for all of your advice.
The only issue i had today was that my Diff Lock light wouldn't go off after i disengaged it. It took a few times for it to release/go off.
Ian
Ian
