Turns out it wasn't the gearbox - it was noise from the fan which eventually came loose and snapped off its blades as I was driving along in the landie on Sunday.
I've been told there may be radiator damage - fingers crossed there isn't - but does anyone know where I could get a replacement fan?
Blackwitch
Non viscous fan
Mine has a viscous fan - 7 plastic blades and plastic hub attached by 4 bolts to a largeish cast finned hub.
According to the parts manual there was also a non-viscous version with 5 metal blades riveted to a pressed metal hub.
It gives the following numbers for the blades part:
viscous (plastic) 614739
non-viscous (metal) 613087
