Post
by map1275 »
Does any one have or can look at the wiring for the Brake Fail relay? I can't find my notes and the manual isn't helpful.
Still using the original 6RA relay.
Post
by Bumpkin »
I've just removed a complete loom from a 82 Series 3. More than likely the same i would say. I'll dig it out.
Post
by map1275 »
Thanks.
Terminal numbers to wire colours will do and if you could check the starter relay at the same time.
