Kiwis, alert! Wanted desperately, sump with baffle.
Kiwistage1V8
Post by Kiwistage1V8 »
Due to the fact the machine shop lost my sump that I had in there being dipped, I now need another one. :evil:
Any one have a spare floating about...?
Stop Global Whining.
I don't but really I would be putting pressure on them to replace it.
Of course the usual suspects exist: Terry Kelk at Heritage Mechanical on the Concourse, Henderson; Morris at Stag 4 x 4, New Lynn; Marcel at Mamaku 4WD, and pretty much anyone else who does Rover V8's.
So, you were getting it dipped. Was that galvanised? Why? I would think that there should be sufficient oil on it to protect it from rust until, well, forever.
Kiwistage1V8
disco2hse wrote:I don't but really I would be putting pressure on them to replace it.
Nah, hot dipped to clean it up.
I had the block & heads getting machined and chucked in a heap of parts to get cleaned in the hot tank at the same time.
I would pressure them into replacing it, but there is a bit of a shitfight going with them at the moment regarding me paying the rest of my bill and I have the rest of the engine assembled in my shed and want to get the damn thing in and going now, not when this is all resolved.
They put a piston on a rod backwards, and I had to get the valve seats refaced because when I got them back there was a dent in 2 of the seats. I took it all elsewhere and the new place said the grind was substandard, so I got the whole lot redone. 3 faces on the valves etc.
Ouch. I can understand that then. Certainly I would be asking them to subsidise the cost of getting someone else who do it properly, i.e. discount the price.
agrojnr
Post by agrojnr »
I have an array of sumps but Im in Western Australia
Adam
One Life Live It
1982 Stage 1 V8 wgn
Kiwistage1V8
Got my sump, but had to pay $75. Ouch. :(
I actually got given a couple, one was from an old 70's rangie and the baffle was not right (attached to the main caps by the look) and the inside of the sump was rusty as hell. I could have made up a baffle and tacked it in place I spose. The other one was huge, it had been modified and would have taken about 10 litres + of oil, and no baffle.
So I ended up getting the right one plus a pickup for $50 + freight.
Bit on the expensive side I thought.
