Imacualte Stage 1 for sale
V8_Disco
Post by V8_Disco »
http://www.landrovercentre.com/stock/cl ... r_sale.htm
in the middle of the page!, wants alot of money for it mind
I had always assumed that mine (wich is in the same comercal configuartion) was a home converson .... what do others think?
the door cards, are they later Defender ones, I dont rememver the screw window ajusters on the second row doors, the fronts are millitarty ones
A
1982, Stage 1 SW LPG
1976, 88 SW
1973, 88 Truck Cab
As the door cards are moulded it would seem correct. I assume operation is the same as the 110 fronts. Just with knob in place of rotating lever.
I have always wanted a set of the middle row doors which are truly split and not false as per normal Ser III.
Money is probably fair but I think you could do better in buying an exceptional example from elsewhere in the world and importing.
Is that rear end original? I don't recall ever seeing kinks in the rear wheel wells before.
Damn smart looking though.
Same kinks as in mine (which is different to LWB) but doesn't appear to have a LH tool bin.
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 500wt_1154
Not a V8 in this case, a high starting price and the usual waffly nonsense description, but still a viable prospect to send around the world and end up with a better car than you can usually find.
V8_Disco
Post by V8_Disco »
I am not looking to buy (well looking for a 4.2/3.9 softdash RRC on LPG) but thought others might be intrested
I would like those second row doors look ace, though I dont like the way the gas splits on the ally millitary tops
Mine has a tool box but does have the wheel arch curve (i think its under ply around the LPG tank)
Cheers for the input, and yes the prices at Huddersfiled LR center are intresting, used to live 2 miles away I think most of them go to the USA ... stock is not that fast moving usefull parts shop though
Aidan
1976, 88 SW
1973, 88 Truck Cab
V8_Disco
Post by V8_Disco »
Ohh and mine has bars between the pillars how have these been removed but keep strengh?
A
1976, 88 SW
1973, 88 Truck Cab
