punter
Posts: 27 Joined: Wed Sep 27, 2006 11:47 pm
Post
by punter » Thu Apr 22, 2010 10:25 pm
Anyone know the standard gear ratio for a 1984 Defender 110?
I've got a stock rolling chassis, with the original V8, Gearbox, and transfer case. Salisbury axels front and rear... no mods.
I need to order some parts, but I'm away from home (can't check my manuals), and I cannot recall what the gear ratio is.
Any help would be greatly appreciated.
cheers,
punter
Posts: 1077 Joined: Mon Jul 21, 2008 2:48 am
Post
by map1275 » Thu Apr 22, 2010 10:47 pm
Which gear ratio?
Posts: 692 Joined: Fri Mar 13, 2009 8:57 pm
Post
by 5988 » Thu Apr 22, 2010 10:51 pm
i assume you mean transfer high ratio?
in which case i dont know (but interested as i have a box from one sat here as well)
Diffs are 3.54 same as RRC/Disco/:ater 110/Stage 1
Main box is same as RRC etc with direct top gear
punter
Post
by punter » Mon Apr 26, 2010 4:36 pm
Sorry about that... yes, I was referring to the transfer case.
cheers,
punter
Pageant Blue 109 V8
Posts: 43 Joined: Sun Feb 07, 2010 12:09 am
Post
by Pageant Blue 109 V8 » Mon Apr 26, 2010 11:51 pm
This is quickly taken from the 1986 Directory:
High Ratios:
RR = 1.174:1
101 = 1.174:1
109 V8 = 1.336: 1
110 V8 = 1.34:1
Low Ratio, all appear to be 3.321:1
The favourite mod was to swop to RR gear cluster.
Paul.
