MRC 9563, Instruction Plate
Pageant Blue 109 V8
Post by Pageant Blue 109 V8 »
MRC 9563 is the Instruction Plate about the use of diff lock and rolling roads for Range-Rover, 4-speed. I guess it is the same as 109 V8, although it does not appear to be listed as a part.
Does anyone have a decent one going spare? I removed mine as it was unreadable.
Regards,
Paul.
They are readily available new.
I have a used one somewhere, however all fitted ones have a serial number stamped into them.
Pageant Blue 109 V8
No, not the VIN plate, I am after the instruction plate inside the cab.
I think it is supposed to be screwed to the bulkhead in front of the main gear lever. About 3" high x 6" long, black with white or silver lettering?
Try this guy charles.north@fphcare.co.nz
He has a couple of ex-army Stage 1's he wrecking and probably has one stuck to a firewall.
http://www.trademe.co.nz/Members/Listin ... ber=559097
I never mentioned the VIN plate.
They instruction plates are readily available new.
Pageant Blue 109 V8
That's the one.
Unfortunately as mere Pommie, I am unable to register on TradeMe and acquire this piece of motoring history - can anyone help?
Regards,
Paul.
I am bidding for some other parts from this guy. How much are you willing to spend and I will bid for you. Remember postage too. We'll sort out payment later (Paypal or something).
