LT 95 + Overdirve idealy
I have now manged to get the parts for the swivel rebuild I want to move on to the leeks in the gear box,
My plan is to find a used LT95 and rebuild it, using a correct speedo gear (the one in is wrong) then idealy mount and overdive and swap the one in service out
change clutch etc while its out
So Looking for a used LT95 not to far away from east yorkshire, anyone got one that needs rehoming
I idealy also want that overdrive I have located a couple but both a fair distance from me ... oh while I think about it how rare are the clutch sleaves for these overdives?
Aidan
Aidan
1982, Stage 1 SW LPG
1976, 88 SW
1973, 88 Truck Cab
1976, 88 SW
1973, 88 Truck Cab
theres one on ebay atm, (even has the OD linkage)
Im watching it as i want the prop flange from it (bit excessive to get a box+Od , but needs must )
OD clutch sleves are NLA as far as i know (if anyone knows otherwise let me know please)
I may have an overdrive spare (but its missing clutch sleeve) , and need to check out the one i intend to fit first
I'm watching it too!
Plan was/is to grab it, copy the linkages and get them remade (I already have someone to make them!)
Re: I'm watching it too!
are you going for it then ...wont bid against you if you are?sebking wrote:Plan was/is to grab it, copy the linkages and get them remade (I already have someone to make them!)
5988 and Seb
Hows this for an idea
Seb you buy it first, get the linkage make copy etc
I buy the box of seb, 5988 as I wont need to flanges we could come to an accomitation!
that is of course unless it goes for stupid money
A
A
1976, 88 SW
1973, 88 Truck Cab
1976, 88 SW
1973, 88 Truck Cab
sounds good
already in 3 figs though...
I have a spare lt95 with OD from a RR in stock already.
I'll bid to what I think the package is worth and then give you first refusal
£200 for a gearbox located in the middle of nowhere.
Too rich for me once the delivery was included.
too much
last lt95 with OD (from a RR) I got was I think £70...
Indeed one of the ODs I have located is with ACH its a hell of a long way from me and its not somewhere I normaly get to. I thought that he only had the OD will ask him about a box as well
5988 - your point about a standerd od is valid
Cheers for the input
Aidan
Aidan
1976, 88 SW
1973, 88 Truck Cab
1976, 88 SW
1973, 88 Truck Cab
