Cheers Rob, link herehttp://forum.landrovernet.com/showthread.php/187720-Part-Number-for-Sun-Visor?p=1448223
Aidan
New Series 3 Stage 1 owner
If you look at page 7 at the sun visor near the bottom part number BA131
http://www.bearmach.com/partscatalogues ... sories.pdf
Is this what you want??
bb
bb
Interesting. Never thought of doing that before and never seen anything around here like that.landiman wrote:The last owner fitted a 88" hard top which was surplus in a workshop in Kuwait, The hard top was originally taken off an 88 that was destined for the Kuwaiti army as they only run soft top's. It's not a bad conversion and works quite well...... i spotted another with this conversion in a classified advert last week, so it's not the only one.
I thought it might have been a muff or something. Again, we never see things like that around here cos it usually doesn't get cold enough. I vaguely remember there being a LR muff that attached to the front grill. It had a mid section that had dome clips that you could use to open or close the muff.landiman wrote:As for the thing hanging from the grille i think it's the last owners attempt at a radiator muff... it's not on there now, but i've had to make another from plastic for running in the cold weather here. A couple of weeks ago we had a lot of snow and as i'm part of a 4x4 i was running about in the bad weather freezing my bits off cos the temp gauge never got off cold. After fitting my rad muff it warmed up lovely.
I've no idea.... it might have been fitted abroard, but i'm certain i've seen similar fitted to series 2's and truck cab versions.
