Hight of Stage 1
V8_Disco
Hight of Stage 1
Post by V8_Disco »
Hi all
Whats the Max hight of a Stage 1 SW with Safari Roof?
Aidan
1982, Stage 1 SW LPG
1976, 88 SW
1973, 88 Truck Cab
Jamie_grieve
Post by Jamie_grieve »
Book says 2.0m/78.7" for V8 station wagon so add how much for the safari roof? 50mm or 2" probably at a guess. Add a lift kit, 40" boggers an who knows :D
redtailhawk
Post by redtailhawk »
hi
The height of 109 station wagon is 81.3 inches had look in my land rover book. I think the height that Jamie is refering toe is for the 88". if you add parabolic springs height will increase by approx 1"also height will change if you change size of tyres . My station wagon is at orginal height and as safari roof until i change to parabolic springs them the fun will begin as i have to lower tyres pressures to get it in the garage now .
Cheers Darren
As per the owner's handbook; Wagon is 2.0M or 78.7". (standard tyres etc.)
Is there a wagon that doesn't have a tropical roof?
There doesn't appear to be a listing anywhere for the optional longer shackles.
Just reading the original question again.... What do you mean by the maximum height?
Larosto
Post by Larosto »
my car has a safariroof and it is 2060 mm high. Tyres are 7,5 16.
regards
Horst
Jamie_grieve
The height I quoted is from Land Rovers own operation manual supplement for the 109 V8. Also relevant would be the type of springs on it now. The book lists 11 leaf fronts and 10 leaf rears which if original would be knackered by now and if replaced may not be original spec. Tyre pressures would make a difference too.
Does it realy matter?
V8_Disco Did you mean standard height for fitting in a garage or something? Or max possible height with modifications?
V8_Disco
Post by V8_Disco »
Thanks chaps its for the car park at work
1976, 88 SW
1973, 88 Truck Cab
