Transfer Box
Transfer Box
I have a problem with my transfer box. I dismounting and se that i have more teeth than in my mouth , and i would like to know where i can by the overhaul kit. Best retgards Arturo.
Land Rover Serie III Stage 1 V8 1982
Land Rover Serie III One Ton
Triumph spitfire MK4 1974
Citroen 2 cv 1990
Mercedes Benz 404 1969
Citroen DS 21 1971
Citroen 11 BL 1938
Opel Rekord 1900 - 1970 And much more....
Citroen 2 cv 1990
Citroen DS 21 1971
Citroen 11 BL 1938
Maybe it would be easier to get the parts from an old Range Rover in Portugal with the same LT 95 gearbox? Maybe even swap the whole gearbox might be easier? Remember the front output on your Landrover is different to the Range Rover so you will need to swap that over.
Bearmach are very good for parts.
Avoid anything with the name 'Britpart'. It's normaly made in China to very poor standards from very bad materials.
Good luck!
Good luck!
The LT230 shafts are like the later LT95 shafts but seem to be more readily available.
They have grooves machined in them unlike most Stage 1 ones, these shafts help with lubrication of the centre pins and gears this prevents what you are looking at in the pictures above.
You can also machine the centre diff housing and use LT230 shims to effectively blueprint the LT95. (a bit difficult as they really were not adjustable from the factory)
Finally is complete and it´s in order. Another qusestion í wqnt to put a kam locker in front where can i have the halfshafts. It´s necessary any other parts.
Best Regards Arturo
Best Regards Arturo
Citroen 2 cv 1990
Citroen DS 21 1971
Citroen 11 BL 1938
Citroen 2 cv 1990
Citroen DS 21 1971
Citroen 11 BL 1938
