does this look right?
does the location of the clutch pipe clips/brackets look correct?
where do the breather pipes fasten to?
where do the brake pipe clip to ...by the piece of rubber id guess there should be a clip soemwhere
Yes
next question then
what goes in the white clip on the clutch pipe bracket? - looks to small to be a fuel pipe ...no brake pipes arround there? ....vacuum for diff lock?
ALso what goes in the clip next to the accelerator linkage ...top leftish of pic?
I would suspect it is the fuel return line. Check your parts list. My car doesn't have anything there as I have the large air cleaner which has two clips for the plastic fuel pipe.
Supply and return are different diameters
thanks
... parts book isn't to good at showing where bits actually go (older S1 and S2 style much better for this)
Both brake pipes are P clipped to the clutch master cover by one P clip and grommet.
Breather pipes are as per your owners handbook.
